2024-10-16 09:38 AM
I am lost in the maze of documentation for AI features at STM.
I have access right now to:
I want to:
My background is in data science, so the 'AI' part I understand. My embedded programming and hardware design knowledge is decent but still beginner level compared to most people here.
So far:
The simplest path I see right now might be to buy a STEVAL-MKI109V3 and use it with Unico instead of the MKBOXPro.
My question is, what is the 'correct' way as of late 2024 to do what I am trying to do. Can I do this with the MKBoxPro?
2024-10-17 01:26 AM
Hello @colin_catlin
The idea behind Edge AI Suite is to provide a comprehensive solution to help developers accelerate their product transformation. Here, developers can find the tools to optimize and deploy machine learning algorithms, from data collection to final deployment on hardware.
This presentation can guide you to select the tool you need.
I guess you are searching for the High Speed Datalog tool, that allows users to manage the acquisition and labelling of sensor datasets via SD card or USB for different STEVAL and NUCLEO boards, included SensorTile.box PRO (STEVAL-MKBOXPRO). The firmware is released both in source code or precompiled, so if you are not interested in embedded programming you are free to flash the precompiled binary directly. It offers also a Python SDK to collect and manage your dataset and convert them in the preferred format. Converters to CSV, Unico and NanoEdge format are natively supported.
Let me know it this solution can help you.
Best regards
Simone
2024-10-17 01:26 AM
Hello @colin_catlin
Best regards
Simone
