2021-07-20 6:45 AM
Hello Community team,
a new article is now available in the Knowledge articles section:
Fan rack condition monitoring with industrial sensor machine learning core --- 1/2
Fan rack condition monitoring with industrial sensor machine learning core --- 2/2
It describes in all the details how to use the Machine Learning Core (MLC) configuration in the ST MEMS sensors that can be found on the STWIN evaluation board. This example shows how MLC functionality embedded in ISM330DHCX can be used for fan rack condition monitoring use case.
Enjoy it!
2021-07-20 6:47 AM
2021-07-20 6:47 AM
