2023-11-05 2:27 AM - edited 2023-11-05 3:02 AM
I meet that when follow func is in its second loop
And I find the value of var 'batch' is not 1 in the second loop,Why?
2023-11-16 4:30 AM
uh..... I fixed many problems by update my Keil MDK...............................
2023-11-10 6:13 AM
Hello @123456dad ,
i'm lacking a lot of context in terms of your configuration and settings with the Cube IA to try and reproduce this behavior but i recommend you check that you have sufficient stack and heap sizes for your project as shown in the snippet below
you can check the User Manuel section 5 for a more detailed explanation .
Hope this helps you .
BR
2023-11-16 4:30 AM
