2019-06-06 10:27 PM
Device Configuration Tool Console doesn't open in STM32CubeIDE.
I clicked "Open Console -> 4 Device Configuration Tool Console". But the console was not opened.
It is important to Validation of X-CUBE-AI application.
Thank you.
2019-07-19 6:21 AM
Hello Yuk117,
My guess is you are looking for Device Configuration Tool Output view.
Please have a try Windows > Show View > Other ... then within "Device Configuration Tool" category please select "Outputs" view.
I confirm such view is required doing AI validation activity.
Please confirm it helps.
Br.
2019-07-19 5:12 AM
I found a following description in features and issues in STM32CubeIDE.
Is it this? I hope to fix this issue.
2019-07-19 6:21 AM
Hello Yuk117,
Br.
2019-07-19 6:06 PM
Thank you! I got outputs of X-CUBE-AI/Validation in Device Configuration Tool Output view.
2021-07-24 5:34 AM
I have found that window hard to get to come up and when it does, it's blank and doesn't have the pin map. It's not up but behind another screen. Restarting the app or deleting excess projects doesn't seem to help. BUT, when I double clicked on the .ioc file, I could see the pin map and related pages. Hope this might help another nube.
2021-07-25 11:00 PM
@EKrie.1 not sure to get your trouble here. STM32CubeIDE output view is same and promoting same services than STM32CubeMX output window. As confirmed by @Yuk117 output windows is fully functional and helps as example AI pack features usage
Only variation is STM32CubeMX is promoting as addon an extra window (tabbed with output one) so called "MCUs selection" this one is not part of STM32CubeIDE. This latest windows is useless if STM32CubeIDE because not supporting device swap.
