2019-06-17 10:31 PM
I have installed the latest STM32IDE (V1.0.1) but I cant see how to add the x-cube-ai package. The suggested method is to use the "Help Menu" -> Manage Embedded software packages" but this is greyed out. I also tried using Help->Install new software, I downloaded the "en.x-cube-ai.zip" package and tried to specify it as alocal install, bu this gives errors too.
2019-06-19 4:05 AM
I resolved same problem.
Open any STM32 project, then "Manage Embedded software packages" will be enabled.
2019-06-19 4:05 AM
2019-06-19 9:43 AM
Thanks that is correct way
