2022-11-16 11:42 PM
Controller: SPC560P44L3 (Custom board)
IDE: SPC Studio
Im facing problems in generating 16kHZ frequency PWM center alignment.
For frequencies below 500Hz I was able to generate PWM center alignment, as per the code generation settings. But going for higher frequencies above 1kHz I see that alignment miss matches.
Please do find the attached code for the reference.
Thank you in advance.
