Rx can't receive data
zeke.huang
Hi all,
Could you check this problem for me? It can not received information from canoe, data(from transceiver) already reached RX pin of SPC5.​
The data transmit from Conoe is : ​
The source code in Attachment.
​I use external OSC is 8M.
CanBitRate is 500 kbps.
Thank you very much.
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
Erwan YVIN
Hello ,
Maybe you should debug the Rx Part by using PLS UDE debugger.
or contact your local FAE.
I have not the environment in order to reproduce the issue.
Best regards
Erwan
Erwan YVIN
Hello ,
Best regards
Erwan
Hi ​Erwan,
Thank you for your reply.
The problem and the solution is that the circuit on the TX side is not connected.
Best regards
Zeke​
