2019-06-26 02:41 AM
Hi all,
Could you check this problem for me? It can not received information from canoe, data(from transceiver) already reached RX pin of SPC5.
The data transmit from Conoe is :
The source code in Attachment.
I use external OSC is 8M.
CanBitRate is 500 kbps.
Thank you very much.
2019-06-28 02:15 AM
Hello ,
Maybe you should debug the Rx Part by using PLS UDE debugger.
or contact your local FAE.
I have not the environment in order to reproduce the issue.
Best regards
Erwan
2019-06-28 02:15 AM
Hello ,
Best regards
Erwan
2019-06-30 11:55 PM
Hi Erwan,
Thank you for your reply.
The problem and the solution is that the circuit on the TX side is not connected.
Best regards
Zeke
