Regarding programming issues with SPC56B series controllers!
‎2024-03-15 12:44 AM
Hello! I bought the development board for SPC560B! When using SPC5STUDIO programming software, I found that I don't know how many functions defined in C language are defined! I just want to ask if you have explanations for the initialization definitions of functions such as clocks, SPI, interrupts, etc., so that I can understand them better! Also, is there any documentation and a summary of common problems related to the programming software SPC5STUDIO that I would like to learn and use!
Thank you!
SPC5 Automotive MCUs
‎2024-04-16 6:16 AM
I suggest to have a look at the AutoDevKit video tutorials available at this link: AutoDevKit on YouTube
The first 4 videos explain how to use SPC5Studio.
To access SPC5Studio component (clock, boot, drivers, etc.) documentation:
- In SPC5Studio project view, right click on component name
- In the context menu, select documentation
- Open the documentation file (usually a .chm file)
Best Regards.
‎2024-04-16 6:16 AM
Best Regards.
