Programming STA8135GA (TESEO V)
  • March 6, 2025
  • 1198 views
Is it possible to write our own firmware for STA8135GA IC? I want to get the raw measurements from the baseband IC in STA8135GA and implement my own navigation algorithm and load the firmware to the IC. Is this possible?
Best answer by GalaxyQuest
For ICs like Teseo-5 we provide PVT generally (you cannot load your navigation solution) but we provide code and carrier phase measurements. Therefore, if you want to implement an RTK algorithm for precise positioning, this is possible.
If you want to implement RTK engine running on a host MPU, you can check out our LIV4F module. LIV4F module also outputs code and carrier phase as MSM7 messages like Teseo-5
Regarding Teseo-5 navigation algorithm, could you please private message me your project details?
Industry/Education/Research?
Volume?
Location?
Thanks,
George
GalaxyQuestBest answer
Volume?
Location?
Thanks,
George
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
enemraAuthor
Thank you for the info. I have sent you a message.
