Low Level Interrupt Control Problem
orhanyilmaz
Posted on November 04, 2014 at 12:58
I'm trying register base interrupt control. But not working.(problem *.s files)
I do not
want to use to OSAL library.
Not starting interrupt. Example Code:
//Orhan YILMAZ
//Timer Example
typedef
enum
FALSE,
TRUE
BOOL
void
StartupInit(
void
void
Port_conig(
void
void
WDT_disable(
void
void
PIT0_Init(unsigned
int
TimeOut);
void
PIT0_Start(
void
//void PIT_0_Handler(void);
void
Interrup_Enable(
void
#include ''components.h''
#include ''xpc560b.h''
* Application entry point.
unsigned
long
i = 0;
int
main(
void
componentsInit();
//CLK Init.
StartupInit();
//WDT Disable
WDT_disable();
//Port
Port_conig();
//Timer
PIT0_Init(0xFFFFF);
//IRQ Config
Interrup_Enable();
PIT0_Start();
while
(TRUE) {
if
(i == 0xFFFFFF)
//SIU.GPDO[90].B.PDO ^= 1;
i = 0;
i++;
//PORT CONFIGURATION
void
Port_conig(
void
//Working Led
SIU.PCR[90].B.OBE = 1;
SIU.GPDO[90].B.PDO = 0;
//Output Low
//PIT0 Initial Function
void
PIT0_Init(unsigned
int
TimeOut)
PIT.PITMCR.R = 0x000000001;
//Enable PIT and Configure to stop in debug mode
PIT.CH[0].LDVAL.R = TimeOut;
//Timeout enter
//Tclk = SystemCLK
INTC_PSR(PIT0_VECTOR)=5;
//PIT_0_Handler, 59, 5;
IRQ_HANDLER(PIT_0_Handler);
//PIT0 Start Function
void
PIT0_Start(
void
//TIE = 1 Timer Interrup Enable
//TEN = 1 Timer Enable
PIT.CH[0].TCTRL.R = 3;
void
WDT_disable(
void
//Watchdog Timer Disable
SWT.SR.R = 0x0000c520;
/* Write keys to clear soft lock bit */
SWT.SR.R = 0x0000d928;
SWT.CR.R = 0x8000010A;
/* Clear watchdog enable (WEN) */
*CLK CONFIGURATION
void
StartupInit(
void
//Check Configurations
while
(ME.GS.B.MTRANS);
//Global Status Register wait for mode transition to complete
while
(ME.GS.B.CURRENTMODE != 4);
//Global Status Register verify RUN0 Current mode
//*********IRQ***********//
void
Interrup_Enable(
void
INTC.CPR.B.PRI = 0;
// Lower INTC's current priority
asm(
''wrteei 1''
//Enable external interrupt ================>>> PROBLEM THIS LINE
void
PIT_0_Handler(
void
PIT.CH[0].TFLG.B.TIF = 1;
Note: ivor.s and vector.s copy my project folder. Thanks. Best Regards, Orhan YILMAZ
Erwan YVIN
Posted on November 14, 2014 at 13:52 Hello Orhan , Do you want enable PIT 0 Channel handler ? if yes , you have to update your application and use the vector59 (Channel PIT 0) your vector59 handler is already defined in hal_lld.c. if you want to customize it stub ''hal_lld.c '' by using PATCH MODE FEATURE in SPC5Studio 3.3 Example Code hal_lld.c :
* @brief PIT channel 0 interrupt handler.
* @isr
#if 0
OSAL_IRQ_HANDLER(vector59) {
OSAL_IRQ_PROLOGUE();
osalSysLockFromISR();
osalOsTimerHandlerI();
osalSysUnlockFromISR();
/* Resets the PIT channel 0 IRQ flag.*/
PIT.CH[0].TFLG.R = 1;
OSAL_IRQ_EPILOGUE();
#endif
Example Code main.c (cf below) V2.0: you can see the LED is blinking when the interruption PIT0 happenned
//Orhan YILMAZ v2.0 (Updated by Erwan)
//Timer Example
typedef
enum
FALSE,
TRUE
BOOL
#define PIT0_VECTOR 59
void
StartupInit(
void
void
Port_conig(
void
void
WDT_disable(
void
void
PIT0_Init(unsigned
int
TimeOut);
void
PIT0_Start(
void
static
void
PIT_0_Handler(
void
* @brief IRQ handler function declaration.
* @details This macro hides the details of an ISR function declaration.
* @param[in] id a vector name as defined in @p vectors.s
#define IRQ_HANDLER(id) void id(void)
void
Interrup_Enable(
void
unsigned
long
i = 0;
int
main(
void
componentsInit();
//CLK Init.
StartupInit();
//WDT Disable
WDT_disable();
//Port
Port_conig();
//Timer
PIT0_Init(0xFFFFF);
//IRQ Config
Interrup_Enable();
PIT0_Start();
while
(TRUE) {
if
(i == 0xFFFFFF)
i = 0;
i++;
void
Port_conig(
void
//Working Led
//Output Low
void
PIT0_Init(unsigned
int
TimeOut)
//Timeout enter
//Tclk = SystemCLK
* @isr
PIT_0_Handler();
void
PIT0_Start(
void
void
WDT_disable(
void
*CLK CONFIGURATION
void
StartupInit(
void
while
(ME.GS.B.MTRANS);
while
void
Interrup_Enable(
void
INTC.CPR.B.PRI = 0;
asm(
''wrteei 1''
static
void
PIT_0_Handler(
void
palTogglePad(PORT_E, PE_LED1);
Best Regards Erwan
3 REPLIES 3
Erwan YVIN
* @isr
#if 0
#endif
//Timer Example
typedef
enum
FALSE,
TRUE
BOOL
void
StartupInit(
void
void
Port_conig(
void
void
WDT_disable(
void
void
PIT0_Init(unsigned
int
TimeOut);
void
PIT0_Start(
void
static
void
PIT_0_Handler(
void
void
Interrup_Enable(
void
unsigned
long
i = 0;
int
main(
void
componentsInit();
//CLK Init.
StartupInit();
//WDT Disable
WDT_disable();
//Port
Port_conig();
//Timer
PIT0_Init(0xFFFFF);
//IRQ Config
Interrup_Enable();
PIT0_Start();
while
(TRUE) {
if
(i == 0xFFFFFF)
i = 0;
i++;
void
Port_conig(
void
//Working Led
//Output Low
void
PIT0_Init(unsigned
int
TimeOut)
//Timeout enter
//Tclk = SystemCLK
* @isr
PIT_0_Handler();
void
PIT0_Start(
void
void
WDT_disable(
void
*CLK CONFIGURATION
void
StartupInit(
void
while
(ME.GS.B.MTRANS);
while
void
Interrup_Enable(
void
INTC.CPR.B.PRI = 0;
asm(
''wrteei 1''
static
void
PIT_0_Handler(
void
Best Regards Erwan
orhanyilmaz
Posted on November 28, 2014 at 13:23
Thanks for reply. But,
I had
to solve
in a different way
. (3 week ago)
Best Regards
Orhan YILMAZ
Posted on August 10, 2017 at 09:00
Hello!
I have the same problem too.
If you don't mind, please let me know the solution in detail.
Thank you.
