I'm using a SPC58EC and trying to assign GPIO pins to some empty pins on the MCU in SPC5 studio, but when I save and close the project and reopen afterwards, I can not see the pins that I assigned in the pinmap editor. Can someone help?
Options
2022-07-26 5:39 AM
1 REPLY 1
Options
2022-08-01 2:44 AM
when you close the pin-map tool, you most save first the modifications done into the pin-map editor
then the modifications are reported to your project configuration, and you must close and save this second window:
then it will work
Best regards
