I'm using a SPC58EC and trying to assign GPIO pins to some empty pins on the MCU in SPC5 studio, but when I save and close the project and reopen afterwards, I can not see the pins that I assigned in the pinmap editor. Can someone help?
CKaya.1
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
1 REPLY 1
ODOUV.1
when you close the pin-map tool, you most save first the modifications done into the pin-map editor
0693W00000QMb3KQAT.pngthen the modifications are reported to your project configuration, and you must close and save this second window:
0693W00000QMb3oQAD.pngthen it will work
Best regards
