2024-05-13 06:57 AM
I am trying to debug a code that are running in core0 and core1. I inserted a breakpoint inside main_core0() and main_core1() infinite loop, but the debugger does not stop on breakpoints. In the core2 the debugger stops on breakpoint.
I am sure that those codes are running because the LEDs that should be blinking by those codes, they are blinking.
I am using a SPC58NH-DISP board and the new AEK-MCU-SPC5LNK dongle configured to OpenOCD protocol.
2024-05-14 03:27 AM
You can debug only one core per time, not in parallel.
Best Regards,
AutoDevKit Team
2024-05-14 03:27 AM
Best Regards,
AutoDevKit Team
