AutoDevKit Ecosystem
Ask questions and find answers on the AutoDevKit solution. Discuss voltage configurations, motor control, and AutoDevKitStudio programming.
Resolved! Is there a charger matching BMS63EN?
I wonder if there is any ST solution on charging a batterypack that already uses the BMS63EN? So that these two could work together in terms of powercontrol. Or is it maybe easier to implement than I think?
Orbiter by Senior
  • 2335 Views
  • 1 replies
  • 1 kudos
Resolved! The CAN example and how to properly make it work
Question 1: When I make the mcanconf like described in AN the second mcanconf is named exact the same, it does not autoincrement to mcanconf1 as it is in the example. Is that important? Or how/when do I link a certain mcanconf to a subsystem? They mu...
Orbiter by Senior
  • 3983 Views
  • 4 replies
  • 2 kudos
Resolved! Am I the only one struggeling or am I the only one using SPC?
Hi everyone!My disappointment has reached the level where I write about it. Mostly to find a way to navigate the  ecosystem or to find an alternative. My initial idea was to move from Atmel 8-bits towards something more powerful. Usecase is automotiv...
Orbiter by Senior
  • 4404 Views
  • 8 replies
  • 1 kudos
Resolved! AEK Examples Import - where to find unchanged examples
The examples are a great resource to get started. But it looks like when making changes to an example it does not only safe in the working folder. It also safes (or changes) the original. After playing a lot with one example I wanted to just delete i...
Orbiter by Senior
  • 2380 Views
  • 3 replies
  • 1 kudos
Resolved! L9963 Library for SPC5 MCU
Hi,I'm looking for C Software library for Battery Management System ST L9963.My setup:IDE: SPC5StudioMCU: SPC570SxxPlease, where can I find this library?ThanksLeo
LeoC by Associate II
  • 2667 Views
  • 3 replies
  • 2 kudos
Resolved! L9963E wakeup
We have a BMS board with SPC574S64 Controller and L9963E as BMS ICI am trying to communicate with the BMS IC via Direct/Normal SPI modeI have done the necessary HW connections properly and ensured the SPI lines are proper.I am trying to communicate w...
VP.6 by Associate II
  • 3055 Views
  • 1 replies
Resolved! SPI communication between L9963E and SPC574S64E3
HiI am trying to configure SPI communication between L9963E and SPC574S64E3I referred the DSPI example in the latest SPC5StudioI could see the baud rate is configured to 1Mbps, 16kb and 26kb But as per the L9963E Spec the baud rate is either 333kbps ...
  • 1955 Views
  • 1 replies
