The FDA802 High Power Output Audio waveform is abnormal
Jping.1
1�?An IIS audio signal that feeds a sine wave
2�?High power output
3�?The audio waveform is abnormal
_legacyfs_online_stmicro_images_0693W00000bkA4SQAU.pngI don't know where the configuration is wrong, please help with some suggestions, thank you.
The desired audio waveform
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
1 REPLY 1
Douglas MILLER
This forum thread was marked by the moderator as needing a little more investigation, so a Support case was created in your name and will be handled off-line.
