Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
Programmatically changing the auto-reload register value
I am using stm32g491ret6 for generating sin, triangle, sawtooth and square waveforms using LUTs.The frequency of the waveforms can be changed by changing the timer auto-reload register value. How I can change the auto-reload register) value programma...
SMajhi by Associate
  • 1408 Views
  • 0 replies
Incorrect audio acquisition with PDM microphone
Hi, I have a problem with audio acquisition using PDM microphones. After using PDM_Filter, single peaks of high amplitude appear in the data in addition to the correct readings. I am using 4 microphones MP34DT01-M, STM32H743 and SAI interface. I take...
RPuch.2 by Associate III
  • 3668 Views
The FDA802 High Power Output Audio waveform is abnormal
1�?An IIS audio signal that feeds a sine wave2�?High power output3�?The audio waveform is abnormalI don't know where the configuration is wrong, please help with some suggestions, thank you.The desired audio waveform
_legacyfs_online_stmicro_images_0693W00000bkA4SQAU.png _legacyfs_online_stmicro_images_0693W00000bkA36QAE.png
Jping.1 by Associate
  • 925 Views
  • 1 replies
tda7498e
Posted on January 29, 2018 at 05:48I've just managed to blow up 2 TDA7498E D Class amp chips when testing the first run of 25 production boards. This is the first time we have managed to damage any chips in over a year of prototype testing.We are us...
STP16NF06 vs IRF520
IRF520 type MOSFETs are starting to be phased out and so in all review, STP16NF06 should be a stable cross reference from what I have read, would anyone know perhaps is there a better cross for an IRF520 than the ST STP16NF06? i have ask OnSemi and t...
MRUEF.1 by Associate
  • 1344 Views
  • 1 replies
