2019-04-12 03:05 AM
I have simulated the spice model of LM2904 in LTSPICE for the input voltages as shown in figure , as per the theoretical calculation output voltage will saturate to supply voltage VCC=12 V , but from simulation results output voltage getting 10.7 Volts.
Kindly suggest me the solution for the same ASAP .
2019-08-01 02:13 AM
as mentioned in datasheet the output voltage swing from 0V to (Vcc+) - 1.5V).
