Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
256D is written on the top of componenet , SOIC8 package I coudlnt find any tecnical information on the internet. Would you please help me what kind of IC is 256D?
Hello; I have the electronic circut card including ST microelectronics IC component. 256D is written on the top of componenet , SOIC8 package I coudlnt find any tecnical information on the internet. According to electronic circuit it seems an OPAMP. ...
TGurl by Associate II
  • 1151 Views
  • 4 replies
I have the electronic circut card including ST microelectronics IC component. On the top of component, 256D is written. Could you please help me what kind of IC is 256D?
Hello; I have the electronic circut card including ST microelectronics IC component. On the top of component, 256D is written. SOIC8 package I couldnt find any tecnical information on the internet. According to electronic circuit, it seems an OPAMP n...
  • 863 Views
  • 1 replies
MC33078:what's the meaning about MZ,GZ,EZ markcode on the top of IC?if it means different places of production? We find that the MC33078 with different markcode influences the tone colour we listen.The MC33078 is used in our KTV PROCESSOR
JYU.11 by Associate
  • 952 Views
  • 0 replies
  • 1 kudos
Simulation output voltage of LM26904A IC in LTSPICE
Hello, I have simulated the spice model of LM2904 in LTSPICE for the input voltages as shown in figure , as per the theoretical calculation output voltage will saturate to supply voltage VCC=12 V , but from simulation results output voltage getting...
KT M by Associate
  • 1070 Views
  • 1 replies
TDA7498e as a monoblock.
If i want to run TDA7498e as a monoblock, do i then need the capacitors on pin 32 / 33..?Both pins are tiet to ground in mono.
RJens.16 by Associate
  • 614 Views
  • 0 replies
Help recognize the correct model of TDA729
Hi, I have an active subwoofer with a burned chip on it. Unfortunately the model number is unreadable in the last number/s. The reading says TDA729* and under it CZ041936. Is there a way to get the correct model? I tried to contact the manufacturer o...
UPari by Associate
  • 680 Views
  • 0 replies
I am looking for STEVAL-STLKT01V1 sensor tile product but I need info regarding how this product friendly with the environment and easy to installation and also security details.
Basically we are thinking to use sensor tile as a voice recognition module and for that we need some info regarding module train process how it will easy for user to train any customize voice ?And this voice recognition module able to distinguish two...
SNaya by Associate
  • 702 Views
  • 0 replies
Guidelines to port codes of ST FP-AUD-SMARTMIC1
Hey guys,I am using a STM32 F411E DISCO board and downloaded ST FP AUD_SMARTMIC1 library to learn audio feedback suppression caused by a mic and a PA ampliflier nearby. In the library C files given in the projects folder of FP AUD_SMARTMIC1, they are...
HS.19 by Associate II
  • 2805 Views
