2022-03-02 1:48 AM
2022-03-02 2:24 AM
Welcome, @esisw.1, to the community!
The pnp bipolar transistor BD140 will be supplied in three groups of the parameter hfe (see datasheet, page 4):
Of course, it always depends on the circuit, but most of the time you can replace a BD140 with a BD140-10 or BD140-16, but not necessarily vice versa.
If you want to be sure that the circuit works safely with the BD140 instead of the BD140-10 or BD140-16, you have to measure the value of hfe of the BD140 and make sure that you are in the appropriate group with it.
Does it answer your question?
/Peter
2022-03-02 2:24 AM
/Peter
2022-03-09 1:04 AM
