Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
Hi Everyone, i'm using a ST 7540 chip for transmitting the digital data through under water, but the challenge infront of me right now is that i am not able to find a suitable transducer for ST 7540.
More Detail,But i found some other transducer which operates in different range than ST 7540. So my question is that is there any way to modulate FSK signal (centre freq 60 khz) to another centre freq. directly without demouldate and modulate again.O...
BEugi.1 by Associate
  • 840 Views
  • 1 replies
CS43L22 noise in speaker
I am designing usb audio card, according to a scheme similar to stm32f469i-disco. Everything works great with the headphones. But when I switch to the speaker mode, there is noise in the speaker. There is noise even when I set the mute mode in the S...
AAndr.13 by Associate
  • 1171 Views
  • 0 replies
[Proximity Sensor ADC with DMA Problem] I have GP2Y0A41SK0F Sharp for distance measuring sensor. the datasheet says it needs 16.5 ms with 3.7 ms tolerant. for sampling time. So I assumed I need to configure PCLK2 (I use ADC2), ADC Clock Prescaller, ...
channel sampling, then calculate those parameters until 16.5 ms found. The problem is kinda impossible to get 16.5 ms even I tried to adjust those parameter. anyone has a clue? Iam using STM32F407VGx
