2016-01-07 07:44 AM
hi, boys.I bought 100 TDA7297 and ran only 2. I wonder if there might be fakes in the market for this Amp Model , or if there is another version that works with other than the proposed schematic datasheet . Someone has something similar happened ?. The number of the batch of every hundred devices is : SINGAPORE W88030938 . Thanks for the help and comments.
#tda72972016-01-07 10:05 PM
Hi Salazar,
TDA7297 was very mature class AB device when ST was still named as SGS-Thomson. according to your description , if your application circuitry (both of schematic and PCB layout) had been proven with TDA7297 in the past , you should get some device that was not ST original . to clarify it , it's better to contact with your dealer. thanks YT2016-01-08 04:24 PM
2016-01-10 10:07 PM
http://www.st.com/web/catalog/sense_power/FM125/CL1503/SC979/PF65157?s_searchtype=partnumber
# it's available in digikey and Mouser . thanks , YT
