Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
I've installed the APWorkbench suite but I'm getting the following message when launching the application: ''APWorkbench I/O warning: No FTDI driver found, APWLink communication will be disabled…..''. Can you please provide more explanation about?
Posted on February 07, 2014 at 10:08I've installed the APWorkbench suite but I'm getting the following message when launching the application: 'APWorkbench I/O warning: No FTDI driver found, APWLink communication will be disabled…..'. Can you please...
nmagniez by Associate II
  • 1406 Views
  • 5 replies
More than stereo recording
Posted on July 03, 2014 at 17:33Is it possible to record multiple mic channels (more than stereo) over USB using the combination of STEVAL-MKI129V3, STEVAL-MKI138V1 and the STEVAL-MKI126V3? #steval-boards-for-mems-mics
TDA7294 High-efficiency Version, +/- 20-volt supply
Posted on July 03, 2014 at 00:14Hello, I had a question of the best way to implement the supplemental +/- 20 VDC *supplemental* supply (i.e., not the +/- 40 VDC main supply). My 40 VDC supply is unregulated. Two thoughts were to use a voltage divide...
mramalfi by Associate
  • 1444 Views
  • 1 replies
TS555
Posted on May 06, 2014 at 00:07TS555CN is a low power version of NE555.TS555CN is made by STAll Datasheets of TS555CN say ''high output current capability''but there is no max output current given in any DataSheet!is the max output current better th...
gerald by Associate
  • 2339 Views
  • 3 replies
STA350BW 2.1 scematic
Posted on April 25, 2014 at 13:57Hi i'm currently using the STA350BW on the demonstration board do you have a  Schematic for 2 (half-bridge) channels + 1 (full-bridge) channel  2.1 mode including recommended component values?Thanks in advance
russell by Associate
  • 962 Views
  • 1 replies
PCB routing of inner balls for 400um flip-chip package on TS4621ML
Posted on April 17, 2014 at 00:24Hi I have a question concerning the PCB routing of the TS4621ML headphone amplifier in 400um flip-chip package.  I have the STEVAL-CCA025V1 demoboard for the TS4621E part and looking at the gerber files for it it app...
jeff by Associate II
  • 2642 Views
  • 6 replies
MPEG-1 Layer II
Posted on April 04, 2014 at 14:29HelloI've been working with STA310 to decode MPEG-1 Layer II compressed elementary streams but it is now obsolete. I would like to know if there is any new component able to decode MPEG-1 Layer II now. Looking at the...
thiago by Associate
  • 1415 Views
  • 3 replies
Choose output channel
Posted on April 09, 2014 at 12:03I am working with a STEVAL-MKI138V1, with a sta321mpl processor and mp34dt01 microphones. I have configured everything and I can control all the inputs, my problem is how can I choose the output channel, the output I...
External Voltage Reference for Analog Read
Posted on April 02, 2014 at 12:32Hey everyone. I am using a STM32F4 - Discovery board to read an analog value from a pressure sensor to convert it into depth. My problem is that the sensor that I need works with 0-5V and my STM32F4 works only with 3...
mejrissi by Associate II
  • 2226 Views
