Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
STDP4020 Firmware Version Detect
Posted on April 03, 2014 at 20:56I am currently working a project to detect the version of STDP4020 firmware. I got all the data bytes of this firmware, can anybody give me some clue how to interpret them, particularly, which part tells the version ...
yao by Associate
  • 1510 Views
  • 1 replies
Music and notification MP3 player
Posted on February 27, 2014 at 11:32For our industrial application, we implemented a STA013 to play sound files located on a SD card. We have to play background music and sometimes play some notification sound. So we send background music MP3 to STA...
nmagniez by Associate II
  • 1034 Views
  • 1 replies
TDA7468 volume control
Posted on October 03, 2013 at 20:24Hello! i have a trouble with setting volume level in TDA7468. I use a wiring diagram as datasheet, and send setting to this IC using the C code:void writer(unsigned char adr_IC, unsigned char adr_reg,unsigned char ...
STA350BW 2ch downmix to 1ch (Mono)
Posted on January 20, 2014 at 09:00Hello, in AP-Workbench and Datasheet, i did not found any Switch to generate ''Mono'' from 2-channel Input, with STA350BW Would this be possible using the PEQ? Thank you best regards, Florian Breu #mono-downmix-...
florian2 by Associate
  • 993 Views
TDA7297 ground layout
Posted on January 28, 2013 at 19:36Hello everyone,I can connect the input ground (from audio source) to power supply ground near the filter capacitors?As about pgnd and signal ground I have to connect both to the power supply ground with diferent ca...
TDA7498MV
Posted on August 21, 2013 at 10:19I was going through the data sheet of the above mentiones Amp, can any one explain me the need for  frequency shift in TDA7498MV
ravi_bv by Associate
  • 829 Views
Shall we use differential TDA7575B input as single ended
Posted on July 25, 2013 at 08:48hi form members,   I am using audio amp. (TDA7575B) which has differential input (IN1+,IN1-) but in our case I have single ended input only from my codec, so i planned to connect IN1- pin to ground with a series capac...
bala by Associate
  • 1194 Views
STA350BW Power Supply
Posted on August 06, 2013 at 12:50Hii want to use the STA350BW amplifier but i am not quite sure which power supply i must use.The first page of the Datasheet says:Four power output configurations(a)– 2 channels of ternary PWM (stereo mode)(2 x 50 W...
joern23 by Associate
  • 958 Views
