Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
Resolved! Does ST provide SPICE models for comparators?
Just wondering if ST provides a SPICE library for the TS985 comparator? I haven't used many parts from ST and could help with any advice. My goal would be to simulate the comparator within LTSpice.Thanks,Alan
alano by Associate
  • 1871 Views
Resolved! About output waveform problem of CS42L51
Hi,This is my previous question(link).I'm implementing 24bit, 44.1kHz audio out code using STM32H7B3-discovery.In previous question, i set SAI(I2S format) buffer like below.I set SAI_A block to output.And, this is my SAI_A setting.​​I set tx buffer t...
0693W00000LyztVQAR.png 0693W00000LyzuiQAB.png 0693W00000LyzusQAB.png 0693W00000Lyzv2QAB.png
Younjun by Associate III
  • 2470 Views
Resolved! Can single TDA7293 handle 100W RMS with 4 ohms?
Hello,I am planning to build amplifier based on single TDA7293 SoC, in class G (as described in technical note). I have 2 voltages, +22/-22 and +45/-45V. The speaker has 4 ohms. Can TDA7293 handle the 100W RMS power, or it is too much for single chip...
MMarg.1 by Associate
  • 3474 Views
  • 4 replies
  • 2 kudos
