‎2019-08-19 6:48 AM
Hello; I have the electronic circut card including ST microelectronics IC component. 256D is written on the top of componenet , SOIC8 package I coudlnt find any tecnical information on the internet. According to electronic circuit it seems an OPAMP. Would you please help me what kind of IC is 256D?
‎2019-08-19 7:50 AM
Only you can tell.
I would not exclude a memory device with serial interface (I2C, SPI).
I'm not a hardware guy, though.
‎2019-08-19 11:05 PM
Thank you for your quick answer. But this component cant be a serial EEPROM or memory devices according to pin connections on PCB design. Do you know where I can learn this part number or who can help me in ST Microelectronics.
‎2019-08-19 11:26 PM
As mentioned, only you know.
Optimally, some ST guy in the know would tell you.
SMD components are quite small, and use short naming codes. Such codes for a specific part is documented in the respective datasheet - which doesn't help if you don't know what it is ...
My guess - a LF156/256/356 compatible opamp.
‎2019-08-19 11:49 PM
Yes you are right. This component is LF256D OPAMP. Thank you so much for your help...:)
