STM8AL3146 Timer not producing calculated PWM frequency at output timer channel
RGatk.1
Hi all,
please suggest some solution for this,
I am trying to produce 14.7khz PWM signal with below timer1 configuration for 16Mhz clock frequency and i am getting 14.53Khz to 14.83Khz.
Why am i getting this frequency variation. Is ST timer can not produce exact output PWM frequency?
F_CK_PSC(prescaler frequency) is 16Mhz and Timer1 configuration are as below.
More than 1 timer channel have been used and all shows same frequency variation
  // enable peripheral clock
  CLK_PCKENR2_bit.PCKEN21 = 1;
  // PWM Mode 1 (output low while TIM1_CNT < TIM1_CCR1); Output-Compare preload enable; CC1 output
  TIM1_CCMR1 = 0x68;
  // PWM Mode 1 (output low while TIM1_CNT < TIM1_CCR2); Output-Compare preload enable; CC2 output
  TIM1_CCMR2 = 0x68;
  // PWM Mode 1 (output low while TIM1_CNT < TIM1_CCR3); Output-Compare preload enable; CC3 output
  TIM1_CCMR3 = 0x68;
  // Enable Timer 1 Ch 1+2 output
  TIM1_CCER1 = 0x11;
  // Enable Timer 1 Ch 3+4 output
  TIM1_CCER2 = 0x01;
  // Main output enable
  TIM1_BKR = 0x81;
  // Set auto-reload register and clock divider to get a base-frequency of 14.7 kHz
  // Calculated by: T_Interrupt = (ARR+1)/f_timer => ARR = 1087; PSCR = 0
  // Note: Maximum ARR , as CCR needs to be lower than ARR
  // Count 0x043F for 14.7KHz
  // Count 0x087F for 7.35KHz
  //TIM1_ARRH = 0x04;
  //TIM1_ARRL = 0x3F;
  // Prescalar is 0
  TIM1_PSCRH = 0x00;
  TIM1_PSCRL = 0x00;
  // Generate update request for setting new register values
  TIM1_EGR_bit.UG = 1;
  // TIM1_ARR unbuffered; Edge-aligned mode; up-counter direction;
  // Counter not stopping on update event; Counter enabled
  TIM1_CR1 = 0x01;
let me know if more information is needed.
Peter BENSCH
Welcome, @RGatk.1​, to the community!
Of course, the timer can provide exact values. However, only if the input frequency of the timer is also exact.
I guess you used the 16MHz HSI as the input frequency for the timer?
However, the HSI uncalibrated has a deviation of 5%, calibrated it is still 1%. Assuming you have calibrated the HSI in your program, your generated frequency will be in the range of 14.553...14.847kHz, uncalibrated 13.965...15.435kHz, which fits your observation quite well.
/Peter
1 REPLY 1
Peter BENSCH
/Peter
