STuW81300 Sub-harmonic reduction for frequency higher 6GHz
AStre
According to data sheet on STuW81300 the ST1.PLL_SEL must be 1 and Nint, Frac must be calculated based on formula on page 25, when VCO frequency if higher than 6GHz. In this case the sub-harmonic at half frequency appears. How could be this sub-harmonic eliminated or reduced significantly?
Thanks,
Alex
Peter BENSCH
The Community is not a technical support team, but a peer-to-peer forum (see Terms and Conditions, article 2 etc). As it is very likely that no community user will be able to help you, please ask your questions again to your local distributor or to the personal Online Support OLS.
/Peter
