2022-04-20 10:35 AM
2022-04-21 03:40 AM
There was a PTN (Product Termination Notification) MDG/21/13040, issued on 2021-10-29. You can find the PDF here, for example.
It mentions the following families:
Last Order Entry Date: 2031-04-30
Last Order Delivery Date: 2031-11-30
As there is and will be no comparable replacement, a redesign is inevitable if the parts are needed beyond the Last Order Delivery Date.
Does it answer your question?
/Peter
2022-04-20 01:02 PM
You should inquire at your local sales office, it's marked as NRND, so assume availability is already low/constrained, and perhaps limited to existing customers for the part.
Given current market conditions, and that it's perhaps 60+ weeks, NCNR, and only at brokers, might be indicative of a redesign being necessary/desirable regardless of the notional EOL/NRND status.
@Peter BENSCH can you check the status on this line, thanks.
2022-04-21 03:40 AM
/Peter
