External clock does not work when programmed from STVP
gocchan
I want to use external clock 16 MHz.
So I implemented the following code.
CLK_ClockSwitchConfig(CLK_SWITCHMODE_AUTO, CLK_SOURCE_HSE, DISABLE, CLK_CURRENTCLOCKSTATE_ENABLE);
It was confirmed that 16MHz oscillated when programmed from STVD.
However, when the same firmware is programmed from STVP, 16MHz does not oscillate.
Why?
Gotoda
gocchan
This issue was due to the hardware (our custom board).
Sorry.
1 REPLY 1
gocchan
Sorry.
