COSMIC Type Cast Problem
laffer
Posted on December 22, 2009 at 12:12
3 REPLIES 3
laffer
Posted on May 17, 2011 at 15:06
We have 2 issues during using COSMIC Compiler 4.3.1 16k Limit version and STVD 4.1.3, R-Link.
First, we don’t have functional value through using Local Variable, when we use as above it shows different value on long_var.
void main(void)
long long_var = 0;
float float_var = 0;
long_var = 533485489;
float_var = (float)long_var;
while (1)
http://www.insem.co.kr/100201/1_local.gif
Second, Type Casting problem.
long long_var = 533485489;
void main(void)
while (1)
It showed wrong value on float_var as it was inserted Type Casting after we declared global variable,
http://www.insem.co.kr/100201/2_cast_fail.gif
however, it goes properly in main function as follows.
long long_var;
void main(void)
while (1)
http://www.insem.co.kr/100201/3_cast_success.gif
We think it has a problem, isn’t it?
krzysztof239955_st
The setting Display Item from Decimal on Standard in debuger solved the problem.
Kris.
luca239955_st
also, when you work with local variables that are not actually used for anything, the compiler sometimes optimize them out: use globals or, at least, declare the locals volatile, to avoid this.
