STM8 MCUs
Discuss STM8 microcontrollers, including SWIM, USART configurations, RTC usage, ADC issues, and debugging.
ST Visual Develop -> Requires size details of text, data, global variables ,bss segment in decimal and hex after build.
Hi Team,I am using STVD version 4.3.12. I am newbie to this.... i wish to know about project information like how much the project size consume after build.like this....(Example shown below)text    data     bss     dec     hex filename6036     ...
I want to display counter values from stm8s to 3 digit seven segment display via 74hc595, but was .unable to do so.Any suggestion will be appreciated .
In my project i have interfaced stm8s003f3 with3 digit 7 segment display via 74hc595d in order to reduce the used pin count in stm8s. From the Stm8s 3 pin are to 74hc595d (sh_cp,st_cp,ds) and three pin to digits pin of 7 segment display. I atta...
Dshar.1 by Associate II
  • 902 Views
  • 0 replies
Problem displaying numbers in 3 digits seven segment display interfaced with 74HC595 shift register? I am trying to send values from stm8s003f3 to display it in 3 digit seven segment display. I have interfaced Stm8s with 74hc595d for pin reduction.
The problem faced is that values send from controller is not displayed on 3 digit seven segment. I am attaching the program please tell me where i am doing wrong./* MAIN.C file *  * Copyright (c) 2002-2005 STMicroelectronics */#include "STM8s.h"void...
AMana.2 by Associate
  • 689 Views
  • 0 replies
Debugger doesn't seem to be working
I have been following this tutorial:http://stm8sdiscovery.nano-age.co.uk/adventures-in-stm8-assembler/getting-started-with-the-blinking-led. When he does the "run to cursor" it stops on the instruction and highlights the editor window. Mine the out...
JTann.1 by Associate II
  • 828 Views
  • 0 replies
how to clear the pending external interrupt
@svlreg INTERRUPT_HANDLER(EXTI_PORTD_IRQHandler, 6){ /* In order to detect unexpected events during development,   it is recommended to set a breakpoint on the following instruction. */ if((SWITCH == RESET) && (flag == SET)) { OFF_STATUS = TRUE; fla...
Trinu by Associate III
  • 1017 Views
  • 0 replies
STM8AF5286 UART3/LINUART not sending data
My following code is not working for sending data over LINUART port of STM8AF5286. I am using STVD and STM8_Standard_Project_Template.GPIO_Init(GPIOD, GPIO_PIN_5, GPIO_MODE_OUT_PP_HIGH_FAST);UART3_DeInit(); UART3_Init(9600,UART3_WORDLENGTH_8D,UART3_S...
PPate.1 by Associate III
  • 976 Views
