When I try to debug STOP0 feature and waking up, MCU can't be programmed by STM32 Cube Programmer. It seems that it is locked. Anybody know how to unlock it?
BWang.1
4 REPLIES 4
Radosław
Senior II
Did you set connect under reset?
BWang.1
Sorry! I need update the information. the possible reason is that the .hex file is not OK. Current I already saved one electronic board by recovering option byte. But another board can't be connected to STM32 Cube Programmer.:face_with_tears_of_joy:
How to connect under reset? set reset to low level and then try to connect?
Radosław
Senior II
this is option in cubeprogrammer.
BWang.1
Already found out it!
Thanks. Tomorrow I will try!
