‎2021-03-29 06:58 PM
‎2021-03-29 11:55 PM
Did you set connect under reset?
‎2021-03-30 01:57 AM
Sorry! I need update the information. the possible reason is that the .hex file is not OK. Current I already saved one electronic board by recovering option byte. But another board can't be connected to STM32 Cube Programmer.:face_with_tears_of_joy:
How to connect under reset? set reset to low level and then try to connect?
‎2021-03-30 02:00 AM
this is option in cubeprogrammer.
‎2021-03-30 02:05 AM
Already found out it!
Thanks. Tomorrow I will try!
