STM32Cube Programmer
SGasp.1
Hi amazing forum..
I am wondering if there is a way to save as HEX file the memory read from the stm32 cube programmer..
I am asking this because I want to check that the bootloader that I am creating is exaclty writing what I expect ...
Thanks a lot guys
KnarfB
Principal III
The blue Read button on the Device Memory tab has a dropdown triangle. Click it and select "Save as..." from the drop-down menu.
hth
KnarfB
4 REPLIES 4
KnarfB
Principal III
hth
KnarfB
Hi KnarfB... I saw it ... it is saving as a bin file... I want to have a HEX file... it is easy for me to do the compariosn with hex values
Just add the suffix .HEX to the filename.
/Peter
fc /b file1.bin file2.bin
