STM32_Programmer_CLI "Error: Failed to Power ON the board !" with STM32N6
cgnd_chris
When I attempt to power cycle a STM32N6570-DK or NUCLEO-N657X0-Q board via the STM32_Programmer_CLI, I get the following error message:
Here is the full log:
❯ STM32_Programmer_CLI --power off index=0 --power on index=0
STM32CubeProgrammer v2.21.0
Power OFF...
Drives the target power pin out of the (onboard) ST-Link.
Info: Power ON/OFF maybe not available on your Board [also not available on standalone probes]
Power OFF the board finished with success !
Power ON...
However, when I attempt the same command on other Nucleo boards, I don't get this error. Here's the same command run on the NUCLEO-H533RE:
Power OFF...
Power ON...
Power ON the board finished with success !
cgnd_chris
FYI, ST-LINK FW is V3J16M8 for all boards.
cgnd_chris
The original post above is what I was seeing on macOS.
When I switch to Windows, I get a different set of errors...
I get the following on the STM32N6570-DK or NUCLEO-N657X0-Q boards:
❯ STM32_Programmer_CLI.exe --power off index=0 --power on index=0
Power OFF...
Error: Failed to Power OFF the board. Cannot getting device information !
Power ON...
On Windows with the NUCLEO-H533RE board:
Power OFF...
Power ON...
Kouthair
Hello there Cgnd_Chris,
Thank you for reporting this issue.
We have reproduced this error and we'll report this to the dedicated team (internal ticket number: 224339).
PS: Ticket number: 224339 is an internal tracking number and is not accessible or usable by customers.
Kouthair
