Problem Erasing Chip Memory - Read Out Protection
‎2021-02-21 8:25 AM
Hello everyone!
I work with a Nucleo board F446RE. One month ago i lended my board to one of my university collegue. After a while he gave me back my board, but i can't use it anymore.
When I try to flash a program with STM32Cube IDE it gives me an error saying:
Error message from debugger back end:
Error finishing flash operation
I find out that my collegue in some way activated the Read Out Protection, and I no way can disable it. I tried to erase chip memory with STM32 ST-LINK Utility, no way, I tried to change Option Byte from level 1to level 0, no luck, I even tried to change the Option Bythes with STM32 Cube Programmer (in RDP section i have FF) and write AA but even that didn't lead to success.
I'm desperate and don't know what to do. I've done a thousand of research in all types of forums no dice!
Anyone who can help me out?
STM32CubeProgrammer
STM32F4 Series
‎2021-02-21 10:44 AM
Well if they set RDP 2 or otherwise broken the chip, then your option is to replace the board. Have your colleague buy one for you.
I would suggest you try strapping the VDD and BOOT0 (BT0) pins together so I doesn't run the user code, and try and come in with the ST-LINK Utilities to recover the device. Try the mass-erase options, and the option bytes. If you can't read the options bytes the device is likely locked out.
If that doesn't work you could perhaps use the J-LINK firmware for the ST-LINK, and see if any of Segger's recovery mechanisms are more productive.
https://www.segger.com/products/debug-probes/j-link/models/other-j-links/st-link-on-board/
‎2021-02-23 9:45 AM
Thank you for your help! I tied to put VDD and BOOT0 together + ST-LINK Utilities, and didn't work, in these days I'll try Segger's recovery method, hope that it will work, otherwise i'll get a new board from my colleague.
Thank you!!!
‎2021-02-23 11:52 AM
Try the Connect Under Reset mode.
‎2021-03-03 7:12 AM
Hi @RHuzy.1​ ,
Can you please tell me if connecting under reset as suggested by @Piranha​ solve your issue?
Hope so :smiling_face_with_smiling_eyes:
Houda
‎2021-03-03 7:28 AM
Signs pointing to No on this one..
‎2021-03-03 7:45 AM
Yes, I tried to connect under reser mode, but doesn't work
