2021-03-21 4:11 AM
when i create this program everything is ok until step7. however i cant pass step 7
and window is below.
2021-03-26 7:50 AM
Hi @Gokhan dönmez ,
To be honest it is the first time we see this behavior :) .
Just to be sure, can you confirm if you install the STM32CubeProgrammer tool using these steps:
Houda
2021-03-22 2:43 AM
Hi Gdönm.1
Can you please tell more informations :
Houda
2021-03-22 3:03 AM
Hİ Houda Ghabri,
Sure ,
i m using version 2.7.0 CubeProgrammer
I m using win10 (64 bits).
Thanks for answer.
Gokhan.
2021-03-23 4:03 AM
Hi @Gokhan dönmez ,
Can you please try to install CubeProgrammer with admin rights in new folder and tell me if it is OK?
Houda
2021-03-23 4:22 AM
Hi Houda Ghabri
I tried to install Cubeprogrammer with admin rights in new folder now but i don't install it.
Gokhan
2021-03-26 7:50 AM
Hi @Gokhan dönmez ,
Houda
2021-04-01 7:35 AM
2022-04-21 2:18 AM
I am having the same problem , I tried above steps and nothing changed.In step7 I can't pass this step.
If you have found the reason, could you please share it!
Thanks .
2022-05-05 12:37 PM
Hi I have the same issue, I tried to load it to a different folder with admin rights as you said but it didn't work. Have anybody solved it?
2022-05-05 1:10 PM
What if you do NOT enable creating any shortcuts on a previous step?
