hi, I am new with the CubeProgrammer_API, I saw that there is a C implementation of this API , is there a C# implementation / Wrapper ? are there any examples of using the CubeProgrammer from dotnet C# ?
Gberl.1
Houda GHABRI
Hi @Gberl.1​
The only examples we provide are C/C++.
in addition to C++, the API is used by STM32CubeProgrammer GUI throw a JNA wrapper, only thoses implementations are tested.
Houda
6 REPLIES 6
Pavel A.
Evangelist III
If you googled, and found nothing, you can be sure that it does not exist.
-- pa
Gberl.1
Pavel, if I googled something and it's not found it doesn't mean it is not somewhere else, maybe someone implemented it and care to share?
Houda GHABRI
Hi @Gberl.1​
Houda
Gberl.1
the PInvoke method is known and common, the problem is that this code has many structures and pointer that should be marshaled, I wonder if any one has done it for this code and cares to share or should I do that work myself.
Mipoter
Hi @Gberl.1,
Recently, you can find a C# wrapper on nuget.
I think it's still in preview, this is the link.
