Error trying to install 32cubeprg 2.19.0 Linux
mx_ch
On Kubuntu 24.04 when double clicking on
SetupSTM32CubeProgrammer-2.19.0.linux
an empty window appears and then closes again.
If I run
via the terminal (as admin or as user), I get this error:
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException at sun.awt.X11FontManager.getFileNameFromPlatformName(X11FontManager.java:174) at sun.font.SunFontManager.initCompositeFonts(SunFontManager.java:3506) at sun.font.SunFontManager.access$800(SunFontManager.java:65) at sun.font.SunFontManager$2.run(SunFontManager.java:555) at java.security.AccessController.doPrivileged(Native Method) at sun.font.SunFontManager.<init>(SunFontManager.java:386) at sun.awt.FcFontManager.<init>(FcFontManager.java:35) at sun.awt.X11FontManager.<init>(X11FontManager.java:57) at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) at java.lang.reflect.Constructor.newInstance(Constructor.java:423) at java.lang.Class.newInstance(Class.java:442) at sun.font.FontManagerFactory$1.run(FontManagerFactory.java:83) at java.security.AccessController.doPrivileged(Native Method) at sun.font.FontManagerFactory.getInstance(FontManagerFactory.java:74) at sun.font.SunFontManager.getInstance(SunFontManager.java:250) at sun.font.FontDesignMetrics.getMetrics(FontDesignMetrics.java:264) at sun.swing.SwingUtilities2.getFontMetrics(SwingUtilities2.java:1125) at javax.swing.JComponent.getFontMetrics(JComponent.java:1626) at sun.swing.SwingUtilities2.getFontMetrics(SwingUtilities2.java:372) at sun.swing.SwingUtilities2.getFontMetrics(SwingUtilities2.java:345) at javax.swing.plaf.basic.BasicLabelUI.paint(BasicLabelUI.java:182) at javax.swing.plaf.ComponentUI.update(ComponentUI.java:161) at javax.swing.JComponent.paintComponent(JComponent.java:780) at javax.swing.JComponent.paint(JComponent.java:1056) at javax.swing.JComponent.paintChildren(JComponent.java:889) at javax.swing.JComponent.paint(JComponent.java:1065) at javax.swing.JComponent.paintChildren(JComponent.java:889) at javax.swing.JComponent.paint(JComponent.java:1065) at javax.swing.JLayeredPane.paint(JLayeredPane.java:586) at javax.swing.JComponent.paintChildren(JComponent.java:889) at javax.swing.JComponent.paintToOffscreen(JComponent.java:5217) at javax.swing.BufferStrategyPaintManager.paint(BufferStrategyPaintManager.java:290) at javax.swing.RepaintManager.paint(RepaintManager.java:1272) at javax.swing.JComponent.paint(JComponent.java:1042) at java.awt.GraphicsCallback$PaintCallback.run(GraphicsCallback.java:39) at sun.awt.SunGraphicsCallback.runOneComponent(SunGraphicsCallback.java:79) at sun.awt.SunGraphicsCallback.runComponents(SunGraphicsCallback.java:116) at java.awt.Container.paint(Container.java:1978) at java.awt.Window.paint(Window.java:3906) at javax.swing.RepaintManager$4.run(RepaintManager.java:842) at javax.swing.RepaintManager$4.run(RepaintManager.java:814) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74) at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:814) at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:789) at javax.swing.RepaintManager.prePaintDirtyRegions(RepaintManager.java:738) at javax.swing.RepaintManager.access$1200(RepaintManager.java:64) at javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1732) at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758) at java.awt.EventQueue.access$500(EventQueue.java:97) at java.awt.EventQueue$3.run(EventQueue.java:709) at java.awt.EventQueue$3.run(EventQueue.java:703) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74) at java.awt.EventQueue.dispatchEvent(EventQueue.java:728) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93) at java.awt.EventDispatchThread.run(EventDispatchThread.java:82) SEVERE: The language pack couldn't be initialized. Action invocation failed SEVERE: com.izforge.izpack.api.exception.IzPackException: java.lang.NullPointerException
View more
Aziz BRIGUI
Hello @mx_ch
Please check this thread: Solved: Re: After upgrade to CubeProgrammer 2.18.0 cannot ... - STMicroelectronics Community
Hope it helps !
Aziz
1 REPLY 1
Aziz BRIGUI
Hello @mx_ch
Hope it helps !
Aziz
