AT25SF128A External Flash Loader
‎2021-10-15 4:33 AM
I used MT25QL128 flash memory in my project. This product was obsolute then, I decided to use AT12SF128 flash memory instead of MT25QL128 . Now, I use STM32 Cube Programmer and can not write external memory . Program give "memory edition verification error".
help please?
- Labels:
QSPI
STM32CubeProgrammer
STM32H7 Series
‎2021-10-21 10:40 PM
I started to write loader code from the beginning. Now , I send write enable command , WEL bit is setted 1. But, chip does not go into QUAD mode, because I do not write status register 2 . I have to do this before I can read memory.
‎2021-10-22 1:32 AM
Sure, for Quad Mode commands SR2.QE needs to be set.
This is indicative of SR2.QE == 0
READ QUAD-6B
00000000 : 99 99 99 99 99 99 99 99-99 99 99 99 9D DD DF FF ................
00000010 : FF FF FF FF FF FF FF FF-FF FF FF FF FF FF FF FF ................
00000020 : FF FF FF FF FF FF FF FF-FF FF FF FF FF FF FF FF ................
00000030 : FF FF FF FF FF FF FF FF-FF FF FF FF FF FF FF FF ................
00000040 : FF FF FF FF FF FF FF FF-FF FF FF FF FF FF FF FF ................
00000050 : FF FF FF FF FF FF FF FF-FF FF FF FF FF FF FF FF ................
00000060 : FF FF FF FF FF FF FF FF-FF FF FF FF FF FF FF FF ................
00000070 : FF FF FF FF FF FF FF FF-FF FF FF FF FF FF FF FF ................
The READ DUAL will work properly.
From a functionality stand-point the chip is a mix of the MICRON and WINBOND
Here where SR2.QE=1
READ ID
AT25SF128A
00000000 : 1F 89 01 1F 89 01 1F 89- ........
REG1 0000 REG2 0002
READ QUAD-6B (000040)
00000000 : 11 22 45 67 FF FF FF FF-FF FF FF FF FF FF FF FF ."Eg............
READ DUAL (000000)
00000000 : FF FF FF FF FF FF FF FF-FF FF FF FF FF FF FF FF ................
00000040 : 11 22 45 67 FF FF FF FF-FF FF FF FF FF FF FF FF ."Eg............
‎2021-10-22 1:36 AM
How can I set SR2.QE ?? My code is :
sCommand.Instruction = 0x50;
sCommand.InstructionMode = QSPI_INSTRUCTION_1_LINE;
sCommand.AddressSize = QSPI_ADDRESS_32_BITS;
sCommand.AlternateByteMode = QSPI_ALTERNATE_BYTES_NONE;
sCommand.DdrMode = QSPI_DDR_MODE_DISABLE;
sCommand.DdrHoldHalfCycle = QSPI_DDR_HHC_ANALOG_DELAY;
sCommand.SIOOMode = QSPI_SIOO_INST_EVERY_CMD;
sCommand.AddressMode = QSPI_ADDRESS_NONE;
sCommand.Address = 0;
sCommand.DataMode = QSPI_DATA_NONE;
sCommand.DummyCycles = 0;
if (HAL_QSPI_Command(&hqspi, &sCommand, HAL_QPSI_TIMEOUT_DEFAULT_VALUE)
!= HAL_OK) {
return HAL_ERROR;
sCommand.Instruction = 0x31;
sCommand.AlternateByteMode = QSPI_ALTERNATE_BYTES_1_LINE;
sCommand.AlternateBytes = 0x02; // QE bit set 1
sCommand.AlternateBytesSize=1;
!= HAL_OK) {
return HAL_ERROR;
if (QSPI_AutoPollingMemReady(0x35,HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK) {
return HAL_ERROR;
‎2021-10-22 6:35 AM
I use a more regular read/write method on the status registers
The Alternate Byte mode, probably
s_command.AlternateByteMode = QSPI_ALTERNATE_BYTES_1_LINE;
s_command.AlternateBytesSize = QSPI_ALTERNATE_BYTES_8_BITS;
s_command.AlternateBytes = 0x02;
‎2021-10-22 6:44 AM
I changed command arrangements then solve problem. Firstly, I create project file and debug methods. Now, Only I have to create Linker file (.stldr file ) for STM32 cube programmer.
‎2021-11-02 11:49 PM
I use same flash memory ( at25sf128) in my project and I can read data from flash correctly, I checked it. However, The images does not have correct view on LCD.
Have you ever had this problem?
- « Previous
- 1
- 2
- Next »
