Wrong code generated on dual-core stm32h747, M4 side
‎2023-12-27 8:51 AM
I want to generate an interrupt on the rising edge of PI0 on the M4 CPU.
Unfortunately, when I program the GPIO With ARM Cortex-M4 pin context assignment, the code generated is as follows in gpio.c:
EXTI_InitStruct.Line_0_31 = LL_EXTI_LINE_0;
EXTI_InitStruct.Line_32_63 = LL_EXTI_LINE_NONE;
EXTI_InitStruct.Line_64_95 = LL_EXTI_LINE_NONE;
EXTI_InitStruct.LineCommand = ENABLE;
EXTI_InitStruct.Mode = LL_EXTI_MODE_IT;
EXTI_InitStruct.Trigger = LL_EXTI_TRIGGER_RISING;
LL_EXTI_Init(&EXTI_InitStruct);
and in stm32h7xx_it.c:
void EXTI0_IRQHandler(void)
if (LL_EXTI_IsActiveFlag_0_31(LL_EXTI_LINE_0) != RESET)
LL_EXTI_ClearFlag_0_31(LL_EXTI_LINE_0);
But this is incorrect because while both init + IRQ executes on the M4, it programs the M7 interrupts delivery.
The correct way to make it work is to replace the following is the code above:
LL_EXTI_MODE_IT => LL_EXTI_MODE_C2_IT
LL_EXTI_IsActiveFlag_0_31() => LL_C2_EXTI_IsActiveFlag_0_31
LL_EXTI_ClearFlag_0_31 => LL_C2_EXTI_ClearFlag_0_31
- Labels:
Bug-report
GPIO-EXTI
STM32H7 Series
‎2024-01-03 8:29 AM
Hello @cberg.1 ,
I escalated the problem to CubeMX team in an internal ticket (ID : 168700 ) to take a closer look at this issue.
(PS: ID 168700 is an internal tracking number and is not accessible or usable by customers).
Thanks.
Mahmoud.
‎2024-01-03 1:57 AM
Hello @cberg.1 ,
First let me thank you for posting and welcome to the ST Community.
Your request is under investigation, and I will get back to you ASAP.
Thanks.
Mahmoud.
‎2024-01-03 8:29 AM
Hello @cberg.1 ,
Thanks.
Mahmoud.
‎2024-08-20 7:07 AM
I don't know the status of your internal bug, but I want to note that:
On version Version: 1.16.0 of STM32CubeIDE, I see that half the bug has been fixed.
- In stm32h7xx_it.c, EXTI0_IRQHandler is generated correctly, with LL_C2_EXTI... functions. Good!
- In gpio.c, the code is still wrong, and use LL_EXTI_MODE_IT instead of LL_EXTI_MODE_C2_IT.
Cedric
