Using the emotas CANOPEN on an STM32F7
CObri.1
I would like to use the CAN interface with a CANOPEN library on my STM32F723.
As I have found there is a Library for STM chips provided by emotas: https://www.st.com/en/partner-products-and-services/canopen.html
I have downloaded the Lib on my STM32CubeIDE an now are trying to add it in my CubeMX to the Project:
The problem is, it says, its not supporting my MCU. But in the description of the Library it says it should support the F7 chips.
Is the library not "free" and I have first to contact emotas or did I forget to install something?
Best regards,
CO
1 REPLY 1
SofLit
I'm checking internally and get back to you as soon as I have a feedback.
Just note that the Emotas stuck is provided as an evaluation version and for commercial usage need to contact them directly.
PS: This is a collaborative space. So please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
