Using FreeRTOS with TrustZone in STM32CubeIDE - STM32L562
2020-03-17 6:47 AM
I have a development kit for the STM32L562, I'm trying to create a blinky-script that will use FreeRTOS to blink a led in the secure-world and the non-secure world simultaneously.
Steps to reproduce:
- Install STM32CubeIDE 1.3.0
- New STM32 Project
- Look for the board that matches l562 in the search bar
- Create project
- Set project name
- Set targeted language to c++
- check "Enable TrustZone"
- click finish
- Click yes to both popups
Once the project is loaded, the following configuration needs to be done in the "projectname.ioc" :
- Go to Middleware->FreeRTOS
- Select "interface: CMSIS_V2"
- save the configuration
- generate the device configuration code
- Right click "projectname_Secure" project and click on "build project"
You should now be getting errors about "FreeRTOS.h" not being found by several files.
If you add '/projectname/Middlewares/Third_Party/FreeRTOS/Source/include' to your include paths, you should no longer be getting the not found error, but should be getting multiple definition errors.
Does anyone know what I'm doing wrong?
Thanks in advance!
- Labels:
STM32CubeIDE
STM32CubeMX
STM32L5 Series
2020-07-06 7:33 AM
Hi @CGuil.1
Sorry the release has been delayed to W30/31.
Best Regards,
Khouloud
- « Previous
- 1
- 2
- Next »
