SystemClock_Config fails at startup after upgrading CubeMX app
TBell.2
I seem to be having an issue on my custom board. I upgraded my CubeMX app and now when I attempt to debug the application fails when HAL_RCC_OscConfig is called in method SystemClock_Config at startup. It's consistent every time. I've scoured the configuration files to no avail.
8 REPLIES 8
Guru
Step through the code, where does it fail within HAL_RCC_OscConfig?
TBell.2
tickstart = HAL_GetTick();
Line 501
TBell.2
It reports a bus fault
TBell.2
If I click reset on the debugger and hit go it gets past this line every time
TBell.2
And, when it runs the software timers don't work at all.
Guru
Perhaps the clock source is unstable or not at the frequency you're expecting. HAL_GetTick is harmless, examine the code yourself.
TBell.2
The clock is internal PLL
TBell.2
When I updated the CubeMX and the port files this started happening
