2014-08-22 04:14 PM
I am trying to configure a new project in STMCubeMX which will utilize the FSMC Nand module. I have several other peripherals obviously and the code generation works fine until I enable the NAND module. I can enable NOR/SRAM with no trouble, but any time I try and enable NAND, it fails. This happens for F2 and F4 series chips. Has anyone else experienced this? I have tried re-installing clean, as well as the eclipse plugin.
#stm32f4 #hal #stcubemx #stm322014-08-25 11:49 AM
This only seems to happen when trying to configure the NAND module to use interrupts instead of the NWAIT line.
