STM332CubeMX fails to copy stm32f7xx_ll_tim.h and generate rules to build stm32f7xx_ll_tim.o when trying to use LL drivers.
‎2021-04-13 5:05 AM
And if I copy it manually, it is deleted on next code-generation
STM32CubeMX
STM32F7 Series
TIM
‎2021-04-14 1:00 AM
Hi @ABlom.2​ ,
Can you please send me your ioc?
Houda
‎2021-04-14 3:05 AM
‎2021-04-15 4:07 PM
Hi @ABlom.2​ ,
I 'm not able to reproduce this issue.
Using your ioc and STM32CubeMX 6.2.1 version (latest one) , stm32f7xx_ll_tim.h is generated correctly under Drivers\STM32F7xx_HAL_Driver\Inc and the Makefile project is compiling perfectly.
Can you please create a new project from scratch and check again?
Houda
‎2021-04-16 1:20 AM
Same result as before, even after cleaning .java/ .stm32cubemx/ .stmcube/ .stmcufinder/
BTW, I'm using the Linux version if that is important...
/Anders
‎2021-04-19 2:10 AM
Hi @ABlom.2​ ,
Yes it is an important information , I will check again using Linux and come back soon with updates.
Houda
