2026-05-28 3:17 AM
I am using the STM32CubeIDE project for the STM32N6570-DK kit.
After enabling the LTDC RGB888 interface, I received a warning (yellow) related to the DEBUG configuration.
I am using “DEBUG Trace Asynchronous SW,” and the message indicates that the DEBUG is partly disabled due to a conflict with LTDC.
Could you please explain the reason for this conflict? As far as I can see, there are no shared pins between the interfaces.
Could this issue affect functionality in any way? Also, how can this warning be resolved or removed?
Thanks,
Omer
2026-05-28 3:31 AM
Welcome to the forum
Please see How to write your question to maximize your chances to find a solution for best results.
You haven't said what version of CubeIDE you're using, but it seems to be an older one - with CubeMX integrated?
Latest versions of CubeIDE (since v2.0.0) have CubeMX entirely separate:
STM32CubeIDE 2.0.0 workflow tutorial
2026-05-28 3:45 AM
I am using STM32CubeMX.
Version 6.17.0
