STM32H750 cubeMX : VREF clock not enabled before calling HAL_SYSCFG_EnableVREFBUF() in HAL_MspInit()
FDESS.2
I think there is a mistake in cubeMX generated HAL_MspInit() when using VREFBuf:
at firmware startup, HAL_MspInit() calls  HAL_SYSCFG_EnableVREFBUF() but the clock of VRREFBuf is not enabled before, so it fails in timeout.
To fix this I have added call of  HAL_SYSCFG_EnableVREFBUF(); at the begining og HAL_MspInit() user code.
Hello @FDESS.2​
Could you please send me your .ioc file to check the issue .
Nesrine
FDESS.2
please find in attach my .ioc as you ask.
In fact, I think that my problem is not really fixed with my workaround, as HAL_SYSCFG_EnableVREFBUF() still exit with timeout...
Thank you,
Fabien
