STM32H747 PA0_C & PA1_C input reading issue
‎2022-09-05 1:15 PM
I am working with a STM32H747XI. I have connected a digital input on PA0_C & PA1_C.
I used CubeMX for the initialisation.
The initialisation code is :
/*Configure GPIO pins : UI_ENC0_Pin UI_ENC1_Pin */
GPIO_InitStruct.Pin = UI_ENC0_Pin|UI_ENC1_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
When I read the pin, it stays always at 0 (GPIO_PIN_RESET)
bpState1 = HAL_GPIO_ReadPin(GPIOA, UI_ENC0_Pin);
bpState2 = HAL_GPIO_ReadPin(GPIOA, UI_ENC1_Pin);
The pin PA0 is at " Reset State".
I dont know what I have to do to solve it.
Many thanks for your help.
Bertrand
STM32CubeMX
STM32H7 Series
‎2022-09-10 1:17 PM
Sorry for the late feedback.
It works!
Many thanks.
Should I report as a bug for CubeMx?
Bertrand
‎2022-09-06 6:46 AM
Hello Bertrand,
are the analog switches between PA0 & PA0_C and PA1 & PA1_C closed?
HAL_SYSCFG_AnalogSwitchConfig(SYSCFG_SWITCH_PA0, SYSCFG_SWITCH_PA0_CLOSE);
HAL_SYSCFG_AnalogSwitchConfig(SYSCFG_SWITCH_PA1, SYSCFG_SWITCH_PA1_CLOSE);
Jaroslav
‎2022-09-06 7:10 AM
I will check and try and revert to you.
Thank you.
Bertrand
‎2022-09-10 1:17 PM
It works!
Many thanks.
Bertrand
‎2022-09-21 7:32 AM
Hello Bertrand,
I'm glad it worked. Concerning the CubeMX bug, I will take care of it.
Jaroslav
